It is currently Sun Aug 24, 2025 10:42 pm
PostPosted: Tue Aug 06, 2013 9:21 am
First name: Wendy
Last Name: W
State: Arizona
So which way do you do it? Pictures, methods, instructions are all appreciated!
Thanks, Wendy
PostPosted: Tue Aug 06, 2013 9:40 am
Last Name: Tulloch
State: Vermont
The short answer is ...After.
PostPosted: Tue Aug 06, 2013 11:14 am
Last Name: Tulloch
State: Vermont
Plus one!
PostPosted: Tue Aug 06, 2013 12:12 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
So....glue the head plate; shape the entire headstock; rout the binding ledge? How do you rout it....lam trimmer? Seems like the router base (like the StewMac precision base with edge guide attached) would be a little bulky for this job.
PostPosted: Tue Aug 06, 2013 12:25 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Stewmac bits/bearings and a router table work well for me.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue Aug 06, 2013 12:27 pm
First name: Wendy
Last Name: W
State: Arizona
Good info Filippo, thanks. I'll 2nd Beth's question. Beth, Burton has a documented build where he uses a 1/16 piloted router bit from Stew Mac to cut the ledge, but he does it before gluing to the headstock, although he glues his headplate to a backing, and his ledge is actually for the purfling and the binding gets glued to the edge of the headplate. So his is actually kind of a cross between the 2 methods. I'd still like to see pictures of the method if anyone has any.
PostPosted: Tue Aug 06, 2013 1:34 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I use the same trimmer on a Williams jig as I do for binding/purfling ledges around a body. Just hold the neck in a vice so that the headstock face is level and around you go.
PostPosted: Fri Aug 09, 2013 5:34 pm
As Wendy mentioned, I do it all before, I find it much easier. Once the headplate is done I make a temporary pattern (usually in 1/2" MDF or similar) of it with a pattern bit on the router table and use that (taped to the headplate) to rout the headstock after they are glued up. I have a master template that I use to make the headplate, if that makes sense. small pins drilled through where the strings will be help for alignment when gluing the plate onto the headstock.
Burton
Brookline, MA.
PostPosted: Fri Aug 09, 2013 8:58 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks Burton, I was hoping you would chime in here, since your documented build, shows the process of making the headplate, but not gluing to and shaping the headstock. Good to know about the temporary pattern. I was planning on using locating pins to glue the headplate in place. Do you cut the front nut edge of the headplate before or after it is glued? Thanks for that documented build by the way. I learned a lot from it!
Wendy
PostPosted: Mon Aug 12, 2013 1:01 pm
Wendy,
Thanks, I'm glad it helped! I do mean to finish it someday but have no idea when that will be-
I sand/plane/shape in the angle before gluing the laminate onto the neck. Then I use the template I made and align it to the headstock tip, it doesn't matter how much I removed on the nut end.
Burton
Brookline, MA.
PostPosted: Mon Aug 12, 2013 1:30 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I can't find Burton's documented build to review it. Can anyone give me the link? Thanks, Beth
PostPosted: Mon Aug 12, 2013 1:42 pm
First name: Wendy
Last Name: W
State: Arizona
viewtopic.php?f=10117&t=29270
See if that works, since I'm not sure how to link it.
PostPosted: Mon Aug 12, 2013 1:51 pm
First name: Wendy
Last Name: W
State: Arizona
I spent a very frustrating 2 days over the weekend trying to bend ebony binding for my headplate. I used a small torch and several sizes of small pipe that got good and hot. I tried different thicknesses of binding and every time it broke. Not my first time bending small radiuses on a pipe, so I think it was the ebony. I tried a metal strap over the outside of the bend. I even tried SuperSoft II. Sprayed it on Saturday night and tried bending late morning on Sunday. Same thing, break, break, break. In a last ditch attempt I am going to try making it extremely thin and, if it will bend, laminating 2 together. About ready to give up! [headinwall]
PostPosted: Mon Aug 12, 2013 4:07 pm
Sometimes ebony can be a real bear to bend.
PostPosted: Mon Aug 12, 2013 7:45 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I once ended up using a black fiber binding on a uke because I kept breaking the ebony during the bend. It ended up looking pretty good....not the best, but maybe it would be okay for just binding the headstock.
PostPosted: Mon Aug 12, 2013 9:36 pm
I always bind mine off the headstock so I can make sure it looks good first.
Old growth, shmold growth!
PostPosted: Tue Aug 13, 2013 4:53 am
With some headstocks geometries, such as the old Gibson style (where its edges are perpendicular to the plane of the strings rather the face of the headstock) it is necessary to bind the overlay with oversize binding, before shaping the heastock, then cut the headstock to size. Because of the "slanting" geometry of the headstock edges, it is not possible to use them as a guide for routing, at least not if the goal is equally wide binding rabbet.
The headstock overlay can be bound either before or after being glued on the oversize headstock, but its final shape must be cut after for this to happen. I usually bind F5-style mandolin headstocks after the overlay is glued on the oversize headstock, which, as I understand, is also how Gibson used to do it. There is a very good article in a recent "American Lutherie" where Andrew Mowry shows how he does it (he binds first).
PostPosted: Tue Aug 13, 2013 8:07 am
OK, that was probably not very easy to understand... Here are a few images of one I did a while back, hopefully they will explain things a bit better
PostPosted: Tue Aug 13, 2013 11:22 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Wow, Arnt! Nice work and excellent documentation of your process. Very helpful to the discussion. Thanks!
PostPosted: Tue Aug 13, 2013 12:39 pm
It looks to me as if the difference is that you can make your headstock binding thicker than the face plate if you bind afterwards. If you bind THEN glue, then the binding will only and always be the thickness of your faceplate. Other than that pretty much any binding scheme can be done before or after, although these mandolin headstocks look like they need to be done prior.
PostPosted: Tue Aug 13, 2013 3:36 pm
First name: Wendy
Last Name: W
State: Arizona
Wow, now I am confused. Arnt, are you referring to the lower headplate curve in the transition area from the neck to the headstock? Or the edge of the whole headstock? Nice work by the way!
PostPosted: Tue Aug 13, 2013 3:39 pm
First name: Wendy
Last Name: W
State: Arizona
Whoops, I should have looked more closely at the pictures before I posted that. I do understand now.
PostPosted: Tue Aug 13, 2013 3:56 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Thanks Arnt, your pics answered several of my questions.
Doug
PostPosted: Tue Aug 13, 2013 7:13 pm
On my first three archtops, I used Stew Macs binding attachment for a Dremel. It worked OK for those instruments doing multiple passes. What I have found it handy for since is routing the ledge when binding headstocks. It will follow most shapes and you aren't confined to the thickness of the headstock veneer if doing it before glueing.
Users browsing this forum: DennisK, Dmaxwell, Jim Watts and 25 guests
